Hardware Information
Chip block diagram​
System block diagram​
Interface description​
No.DescriptionNo.DescriptionNo.Description
1WiFi 6 & BT 5.4 module2Antenna connector3SPI Flash (unsoldered)
4Rockchip RK35765Status LED6LPDDR5
7Maskrom button8Onboard eMMC9260-pin SO-DIMM connector
10Onboard UFS (unsoldered)
  • Power LED
Under normal conditions, the power LED (green) on the Radxa NX4 IO Board turns on, indicating that power is normal.
  • User LED
The status LED (blue) on Radxa NX4 blinks, indicating that the system is running normally.
