YOLOv5 Object Detection on Device
This document demonstrates how to run on-device inference of the YOLOv5 object detection model on Rockchip RK3588/3566 series chips. For the required environment setup, please refer to RKNN Installation.
This example uses a pre-trained ONNX model from the rknn_model_zoo as a case study, showing the complete process from model conversion to on-device inference.
Deploying YOLOv5 with RKNN involves two main steps:
  • On the PC, use rknn-toolkit2 to convert models from different frameworks into RKNN format.
  • On the device, use the Python API of rknn-toolkit2-lite to run inference.
Model Conversion on PC​
Radxa provides a pre-converted yolov5s_rk35XX.rknn model. Users can skip the PC-side model conversion section and directly refer to YOLOv5 Inference on Device.
  • If you are using Conda, first activate the rknn Conda environment:
    X86 Linux PC
    conda activate rknn
  • Clone the rknn_model_zoo repository:
    X86 Linux PC
    git clone -b v2.3.0 https://github.com/airockchip/rknn_model_zoo.git
  • Download the yolov5s_relu.onnx model:
    X86 Linux PC
    cd rknn_model_zoo/examples/yolov5/model
    # Download the pre-trained yolov5s_relu.onnx model
    bash download_model.sh
    If you encounter network issues, you can visit this page to manually download the model and place it in the corresponding folder.
  • Convert the ONNX model to yolov5s_relu.rknn using rknn-toolkit2:
    X86 Linux PC
    cd rknn_model_zoo/examples/yolov5/python
    # python3 convert.py ../model/yolov5s_relu.onnx rk3588 i8 ../model/yolov5s_relu_rk3588.rknn
    Parameter explanation:
    • <TARGET_PLATFORM>: Name of the NPU platform. Options: rk3562, rk3566, rk3568, rk3576, rk3588, rk1808, rv1109, rv1126.
    • <dtype>: Choose i8 or fp. i8 is for INT8 quantization; fp is for FP16 quantization. The default is i8.
    • <output_rknn_path>: Path to save the RKNN model. By default it is saved in the same directory as the ONNX model.
    For RK358X users, set TARGET_PLATFORM to rk3588.
  • Copy the generated RKNN model to the device.
YOLOv5 Inference on Device​
For RK356X products, you must enable the NPU using rsetup before running NPU workloads:
sudo rsetup -> Overlays -> Manage overlays -> Enable NPU, then reboot the system.
If there is no Enable NPU option in Overlays, please run: sudo rsetup -> System -> System Update to upgrade the system, reboot, and then repeat the above steps to enable the NPU.
  • (Optional) Download the YOLOv5s RKNN models prepared by Radxa:
    PlatformDownload Link
    rk3566yolov5s_rk3566.rknn
    rk3568yolov5s_rk3568.rknn
    rk3588yolov5s_rk3588.rknn
  • Modify rknn_model_zoo/py_utils/rknn_executor.py (remember to back up the original code):
    Configure the RKNN Model Zoo repository as described in RKNN Model Zoo.
    Python Code
    from rknnlite.api import RKNNLite as RKNN
    class RKNN_model_container():
    rknn = RKNN()
    rknn.load_rknn(model_path)
    ret = rknn.init_runtime()
    self.rknn = rknn
    def run(self, inputs):
    if self.rknn is None:
    print("ERROR: rknn has been released")
    return []
    pass
    else:
    inputs = [inputs]
    return result
    def release(self):
    self.rknn.release()
    self.rknn = None
  • Modify line 262 in rknn_model_zoo/examples/yolov5/python/yolov5.py (remember to back up the original code):
    Python Code
    262 outputs = model.run([np.expand_dims(input_data, 0)])
  • Enter the virtual environment:
    For virtual environment usage, refer to Python Virtual Environment Usage.
    To install the rknn_toolkit-lite2 Python API, see Install rknn_toolkit-lite2.
  • Install dependencies:
  • Run the YOLOv5 example:
    Radxa OS
    python3 yolov5.py --model_path <your model path> --img_save
    If you are using a model converted on the PC, copy it from the PC to the device and specify the model path with the --model_path parameter.
    Results
    (.venv) rock@rock-5b-plus:~/rknn_model_zoo/examples/yolov5/python$ python3 yolov5.py --model_path ./yolov5s_relu_rk3588.rknn --img_save
    use anchors from '../model/anchors_yolov5.txt', which is [[[10.0, 13.0], [16.0, 30.0], [33.0, 23.0]], [[30.0, 61.0], [62.0, 45.0], [59.0, 119.0]], [[116.0, 90.0], [156.0, 198.0], [373.0, 326.0]]]
    W rknn-toolkit-lite2 version: 2.3.0
    I RKNN: [07:00:34.201] RKNN Runtime Information, librknnrt version: 2.3.0 (c949ad889d@2024-11-07T11:35:33)
    I RKNN: [07:00:34.201] RKNN Driver Information, version: 0.9.6
    I RKNN: [07:00:34.202] RKNN Model Information, version: 6, toolkit version: 2.3.0(compiler version: 2.3.0 (c949ad889d@2024-11-07T11:39:30)), target: RKNPU v2, target platform: rk3588, framework name: ONNX, framework layout: NCHW, model inference type: static_shape
    W RKNN: [07:00:34.225] query RKNN_QUERY_INPUT_DYNAMIC_RANGE error, rknn model is static shape type, please export rknn with dynamic_shapes
    Model-./yolov5s_relu_rk3588.rknn is rknn model, starting val
    infer 1/1
    IMG: bus.jpg
    person @ (209 243 286 510) 0.880
    person @ (479 238 560 526) 0.871
    person @ (109 238 231 534) 0.840
    person @ (79 353 121 517) 0.301
    bus @ (91 129 555 464) 0.692
    Detection result save to ./result/bus.jpg
    • --model_path: Path to the RKNN model.
    • --img_folder: Folder containing images for inference, default is ../model.
    • --img_save: Whether to save the inference result images to ./result. Default is False.
  • All inference results are stored in the ./result directory.
