Simulated Inference YOLOv5 Segmentation Model
This document demonstrates how to use rknn-toolkit2 on an x86 PC to perform simulation inference of the YOLOv5 segmentation model without a motherboard. For the required environment setup, please refer to RKNN Installation.
Prepare the Model​
This example uses a pre-trained ONNX model from the rknn_model_zoo as a case study, converting the model and running simulation inference on the PC.
  • If you are using Conda, first activate the rknn Conda environment:
    X86 Linux PC
    conda activate rknn
  • Download the yolov5s-seg.onnx model:
    X86 Linux PC
    cd rknn_model_zoo/examples/yolov5_seg/model
    # Download the pre-trained yolov5s-seg.onnx model
    bash download_model.sh
    If you encounter network issues, you can visit this page to manually download the model and place it in the corresponding folder.
  • Rename the ONNX model file suffix to .rknn (only for PC-side result simulation):
    X86 Linux PC
    cp yolov5s-seg.onnx yolov5s-seg.rknn
  • (Optional) Use rknn-toolkit2 to convert the model to yolov5s-seg.rknn:
    X86 Linux PC
    cd rknn_model_zoo/examples/yolov5_seg/python
    # python3 convert.py ../model/yolov5s-seg.onnx rk3588 i8 ../model/yolov5s-seg.rknn
    Parameter explanation:
    • <TARGET_PLATFORM>: Name of the NPU platform. Options: rk3562, rk3566, rk3568, rk3576, rk3588, rk1808, rv1109, rv1126.
    • <dtype>: Choose i8 or fp. i8 is for INT8 quantization; fp is for FP16 quantization. The default is i8.
    • <output_rknn_path>: Path to save the RKNN model. By default it is saved in the same directory as the ONNX model with the filename yolov5s-seg.rknn.
    For RK358X users, set TARGET_PLATFORM to rk3588.
ONNX Model Inference on PC​
X86 Linux PC
python3 yolov5_seg.py --model_path ../model/yolov5s-seg.onnx --img_show
Result
person @ (212 242 285 510) 0.871
person @ (111 240 223 535) 0.850
person @ (472 233 559 519) 0.831
bus @ (97 134 549 458) 0.799
person @ (80 328 125 517) 0.470
RKNN Model Simulation Inference on PC​
  • Install the required dependencies with pip3:
    X86 Linux PC
    pip3 install torchvision==0.19.0 pycocotools
  • Run the simulation inference script:
    • Modify rknn_model_zoo/py_utils/rknn_executor.py to the following code (be sure to back up the original file):
      Python Code
      from rknn.api import RKNN
      class RKNN_model_container():
      rknn = RKNN()
      DATASET_PATH = '../../../datasets/COCO/coco_subset_20.txt'
      onnx_model = model_path[:-4] + 'onnx'
      rknn.config(mean_values=[[0, 0, 0]], std_values=[[255, 255, 255]], target_platform=target)
      rknn.load_onnx(model=onnx_model)
      rknn.build(do_quantization=True, dataset=DATASET_PATH)
      rknn.init_runtime()
      self.rknn = rknn
      def run(self, inputs):
      pass
      else:
      inputs = [inputs]
      return result
      def release(self):
      self.rknn.release()
      self.rknn = None
      X86 Linux PC
      python3 yolov5_seg.py --target <TARGET_PLATFORM> --model_path <RKNN_MODEL_PATH> --img_show
      # python3 yolov5_seg.py --target rk3588 --model_path ../model/yolov5s-seg.rknn --img_show
      --target: Name of the NPU platform to simulate. Options: rk3562, rk3566, rk3568, rk3576, rk3588, rk1808, rv1109, rv1126.
      --model_path: Path to the RKNN model to be simulated.
      Results
      person @ (213 239 284 516) 0.882
      person @ (109 240 224 535) 0.869
      person @ (473 231 560 523) 0.845
      bus @ (97 136 548 459) 0.821
      person @ (80 328 124 519) 0.499
    • Simulation inference result (the simulator only simulates NPU computation; actual performance and accuracy are determined by inference on the target board):
