Serial Login
Serial login is a core method for interacting with the board via serial communication interface (UART) in embedded development. Through serial tools, you can view system logs and perform command-line interactions.
danger
When using a USB serial data cable to connect to the board for serial debugging, please ensure the pin connections are correct. Connecting pins incorrectly may cause hardware damage to the board.
Do not connect the USB serial data cable's VCC interface (red wire). Connecting it incorrectly may damage the board.
Connect the USB serial data cable to the UART2 interface on the Radxa NX5 Development Kit, and the other end to the PC's USB port.
Note: Please follow the USB serial cable manufacturer's pin definitions for connection. The diagram shows common USB serial cable pin definitions.
Radxa NX5 Development KitConnection Method
GND (Pin 6)Connect the GND pin of the Radxa NX5 Development Kit to the GND pin of the USB serial cable (black Dupont wire)
UART2_TXD (Pin 8)Connect the UART2_TXD pin of the Radxa NX5 Development Kit to the RXD pin of the USB serial cable (white Dupont wire)
UART2_RXD (Pin 10)Connect the UART2_RXD pin of the Radxa NX5 Development Kit to the TXD pin of the USB serial cable (green Dupont wire)
Serial Login​
Serial Communication Parameters
Baud Rate: 1500000
Data Bits: 8
Stop Bits: 1
Parity: None
Flow Control: None
Using Tabby​
Download Tabby​
Install Tabby​
Using Tabby​
Serial Port Configuration​
Select Serial Port Template​
Modify Serial Port Parameters​
③ --> Baud rate : Set the baud rate to 1500000
Serial Port Device Number
Login via Serial Port​
After a successful connection, press Enter to display the command line interface.
Using the Serial Port​
Once successfully logged in via the serial port, you can view system logs and run commands to test system functionality through the serial port.
