Convert Custom Trained YOLO Models
This document explains how to convert your own trained YOLO models to RKNN and run them on-device with a Rockchip NPU. Many users can run the YOLO demos in RKNN Model Zoo, but struggle when converting custom-trained models.
This guide applies to:
  • ultralytics-yolov5
  • yolov6
  • yolov7
  • ultralytics-yolov8
  • yolov10
  • YOLOX
  • ultralytics-yolo11
  • YOLO-World
This guide uses a custom-trained yolo11n model as an example (head detection). The model and test data were provided by Radxa community user @sanskarjainba-hub.
Why custom models often fail to convert​
The YOLO models shipped in RKNN Model Zoo usually include extra post-processing blocks or have different output layouts compared to your own exported models. For example, the official YOLO11 model in RKNN Model Zoo outputs multiple heads, while a typical custom model may output a single head.
Output layout of the YOLO11n model from RKNN Model Zoo
Output layout of a custom-trained YOLO11n model
Typical differences:
  • Remove post-processing layers inside the model (post-process outputs are not quantization-friendly).
  • Move DFL / decode logic to CPU-side post-processing (often faster on NPU overall).
  • Optionally add helper outputs to speed up threshold filtering during post-processing.
When you remove these blocks, you must do post-processing on the CPU (you can reuse implementations from RKNN Model Zoo).
Model conversion approaches​
There are two practical approaches:
  1. FP16 / mixed quantization (keep your existing post-processing)
    • Fastest path, minimal code changes.
    • Performance improvement is limited compared to a fully optimized INT8 pipeline.
  2. INT8 quantization (use RKNN Model Zoo post-processing)
    • Best performance.
    • Requires adjusting the model output structure and using external post-processing.
Prepare the model and test input​
Have your PyTorch model (e.g. best.pt) and a test image.
Test image
Baseline: CPU inference with the PyTorch model​
Run a baseline with ultralytics on the device:
pip3 install -U ultralytics
yolo predict model=best.pt source="../test_img/frame_00304.jpg"
Example output:
image 1/1 ...: 384x640 3 PERSONs, 268.8ms
Speed: ... 268.8ms inference ...
In this example, the PyTorch CPU inference time is 268.8 ms.
best.pt inference result
Approach A: FP16 RKNN (minimal changes)​
If your model is an Ultralytics model, you can convert directly:
X86 Linux PC
yolo export model=best.pt format=rknn name=rk3588
The result will be saved to ./best_rknn_model.
Run inference with the FP16 RKNN model​
Copy the best_rknn_model folder to the device and run:
yolo predict model="./best_rknn_model" source="../test_img/frame_00304.jpg"
Example output:
image 1/1 ...: 640x640 3 PERSONs, 64.3ms
Speed: ... 64.3ms inference ...
In this example, FP16 RKNN inference time is 64.3 ms.
FP16 RKNN inference result
Convert with Model Zoo scripts (non-Ultralytics models)​
If your model is not an Ultralytics export, RKNN Model Zoo provides python/convert.py scripts under the corresponding YOLO example directories. Export your model to ONNX first and then convert to RKNN with quant_dtype=fp.
See: Deploy YOLOv5 on the Device.
Approach B: INT8 RKNN (best performance)​
Quantizing YOLO models to INT8 usually requires removing in-model post-processing and using external post-processing (Model Zoo style).
Rockchip provides optimized conversion repos for different YOLO versions:
ModelRepoREADME
yolov5https://github.com/airockchip/yolov5https://github.com/airockchip/yolov5/blob/master/README_rkopt.md
yolov6https://github.com/airockchip/YOLOv6https://github.com/airockchip/YOLOv6/blob/main/deploy/RKNN/RKOPT_README.md
yolov7https://github.com/airockchip/yolov7https://github.com/airockchip/yolov7/blob/main/README_rkopt.md
yolov8https://github.com/airockchip/ultralytics_yolov8https://github.com/airockchip/ultralytics_yolov8/blob/main/RKOPT_README.md
yolov10https://github.com/airockchip/yolov10https://github.com/airockchip/yolov10/blob/main/RKNN_README_EN.md
YOLOXhttps://github.com/airockchip/YOLOXhttps://github.com/airockchip/YOLOX/blob/main/README_rkopt.md
yolo11https://github.com/airockchip/ultralytics_yolo11https://github.com/airockchip/ultralytics_yolo11/blob/main/RKOPT_README.md
YOLO-Worldhttps://github.com/airockchip/YOLO-Worldhttps://github.com/airockchip/YOLO-World/blob/master/RKNN_README_EN.md
Follow the README for your model family to export an optimized ONNX, then convert to INT8 RKNN with your calibration dataset.
Example (YOLO11):
X86 Linux PC
git clone https://github.com/airockchip/ultralytics_yolo11.git
After converting, run inference on-device using RKNN Model Zoo-style post-processing.
ONNX inference result (after structure changes)
INT8 RKNN inference result
Performance summary (example)​
ModelTypeBackendTime
best.ptFP32CPU268.8 ms
best.onnxFP32CPU112.08 ms
best_fp.rknnFP16NPU64.3 ms
best_int8.rknnINT8NPU18.74 ms
In this example, moving a custom YOLO11n model from CPU to NPU improves inference time from 268.8 ms to 18.74 ms (~14× speedup) while keeping comparable detection results.
