ROS 组件性能基准测试
评估 ROS 组件在 Q900 上的性能表现,支持标准 ROS 消息类型和 QRB Transport DMA-BUF 零拷贝类型。
前提条件​
开箱即用​
步骤 1:安装​
sudo apt install -y ros-jazzy-qrb-ros-benchmark
步骤 2:创建基准测试模板​
以下模板测试 QRB Transport Image 类型(DMA-BUF 零拷贝传输),已修正官方文档中缺失的 topic remapping:
cat > image_benchmark.launch.py << 'EOF'
from launch_ros.actions import ComposableNodeContainer
from launch_ros.descriptions import ComposableNode
from ros2_benchmark import ROS2BenchmarkConfig, ROS2BenchmarkTest
def launch_setup(container_prefix, container_sigterm_timeout):
data_loader_node = ComposableNode(
name='DataLoaderNode',
namespace=TestQrbNode.generate_namespace(),
package='ros2_benchmark',
plugin='ros2_benchmark::DataLoaderNode',
remappings=[('data_loader_image', '/data_loader_image')],
playback_node = ComposableNode(
name='QrbPlaybackNode',
package='qrb_ros_benchmark',
plugin='qrb_ros::benchmark::QrbPlaybackNode',
parameters=[{
'data_formats': ['qrb_ros/transport/type/Image'],
remappings=[
('buffer/input0', '/data_loader_image'),
('input0', '/playback_image'),
monitor_node = ComposableNode(
name='QrbMonitorNode',
plugin='qrb_ros::benchmark::QrbMonitorNode',
parameters=[{
'monitor_data_format': 'qrb_ros/transport/type/Image',
remappings=[('output', '/playback_image')],
container = ComposableNodeContainer(
name='container',
package='rclcpp_components',
executable='component_container_mt',
prefix=container_prefix,
sigterm_timeout=container_sigterm_timeout,
composable_node_descriptions=[
data_loader_node,
playback_node,
monitor_node,
output='screen',
return [container]
def generate_test_description():
return TestQrbNode.generate_test_description_with_nsys(launch_setup)
class TestQrbNode(ROS2BenchmarkTest):
config = ROS2BenchmarkConfig(
benchmark_name='QRB Image Transport Benchmark',
input_data_path='/path/to/rosbag',
publisher_upper_frequency=100.0,
publisher_lower_frequency=100.0,
playback_message_buffer_size=10,
test_iterations=3,
def test_benchmark(self):
self.run_benchmark()
EOF
关键参数说明:
  • input_data_path:指向测试 rosbag 的路径
  • publisher_upper_frequency / publisher_lower_frequency:搜索窗口上限/下限
  • test_iterations:迭代次数,建议至少 3 次以避免统计边界 bug
步骤 3:生成测试 rosbag​
python3 -c "
from ros2_benchmark import RosbagGenerator
RosbagGenerator.generate_fixed_messages(
output_path='image_bag',
topic_name='/data_loader_image',
msg_type='sensor_msgs/msg/Image',
resolution=(320, 240),
encoding='rgb8',
message_count=10,
步骤 4:运行基准测试​
launch_test image_benchmark.launch.py input_data_path:=image_bag
源码构建​
步骤 1:克隆仓库​
git clone https://github.com/qualcomm-qrb-ros/qrb_ros_benchmark.git
git clone https://github.com/qualcomm-qrb-ros/ros2_benchmark.git
git clone https://github.com/qualcomm-qrb-ros/qrb_ros_transport.git
git clone https://github.com/qualcomm-qrb-ros/lib_mem_dmabuf.git
git clone https://github.com/qualcomm-qrb-ros/qrb_ros_imu.git
git clone https://github.com/qualcomm-qrb-ros/dmabuf_transport.git
步骤 2:构建​
cd ~/qrb_ros_ws
colcon build
步骤 3:运行​
source ~/qrb_ros_ws/install/setup.bash
预期输出​
预测可持续频率:       99.375 Hz
实际平均接收速率: 99.867 FPS
发送帧数: 198
丢帧: 0
平均帧间抖动: 0.312 ms
平均 CPU: 2.074%
Ran 1 test
OK
APT 1.0.0 版在测试完成后卸载组件时可能发生段错误(不影响已生成的 benchmark 数据),源码版已修复。
