ROS 消息零拷贝传输
QRB ROS Transport 基于 REP 2007 实现 DMA-BUF 零拷贝传输——在 ROS 节点间传递文件描述符而非拷贝图像数据。支持 Image、IMU、PointCloud2 三种类型。
前提条件​
  • 已完成 QIR SDK 安装
  • 确认 DMA heap 可用:ls /dev/dma_heap/system
方式一:最小验证代码​
编写发布/订阅两个节点,从 /dev/dma_heap/system 分配 DMA-BUF,写入 64×48 NV12 图像并发布,订阅端逐字节校验。
创建测试包​
选取任意目录作为 colcon workspace,在其中创建包:
mkdir -p [your_workspace]/src/qrb_transport_test/src && cd $_
package.xml​
cat > package.xml << 'EOF'
<?xml version="1.0"?>
<package format="3">
<name>qrb_transport_test</name>
<version>0.0.1</version>
<description>QRB ROS Transport zero-copy test</description>
<maintainer email="[email protected]">user</maintainer>
<license>Apache-2.0</license>
<buildtool_depend>ament_cmake</buildtool_depend>
<depend>rclcpp</depend>
<depend>sensor_msgs</depend>
<depend>qrb_ros_transport_image_type</depend>
<depend>lib_mem_dmabuf</depend>
<export><build_type>ament_cmake</build_type></export>
</package>
EOF
CMakeLists.txt​
cat > CMakeLists.txt << 'EOF'
cmake_minimum_required(VERSION 3.8)
project(qrb_transport_test)
find_package(ament_cmake REQUIRED)
find_package(rclcpp REQUIRED)
find_package(sensor_msgs REQUIRED)
find_package(qrb_ros_transport_image_type REQUIRED)
find_package(lib_mem_dmabuf REQUIRED)
add_executable(image_transport_test src/image_transport_test.cpp)
ament_target_dependencies(image_transport_test
rclcpp sensor_msgs qrb_ros_transport_image_type lib_mem_dmabuf)
install(TARGETS image_transport_test DESTINATION lib/${PROJECT_NAME})
ament_package()
EOF
image_transport_test.cpp​
cat > src/image_transport_test.cpp << 'EOF'
#include <cstdint>
#include <memory>
#include <string>
#include <vector>
#include "qrb_ros_transport_image_type/image.hpp"
#include "qrb_ros_transport_image_type/image_utils.hpp"
#include "rclcpp/rclcpp.hpp"
using Image = qrb_ros::transport::type::Image;
class PublisherNode : public rclcpp::Node {
public:
PublisherNode() : Node("qrb_transport_test_publisher") {
publisher_ = create_publisher<Image>("qrb_transport_test/image", 10);
timer_ = create_wall_timer(std::chrono::milliseconds(500),
[this]() { publish_image(); });
private:
void publish_image() {
constexpr int width = 64, height = 48;
constexpr char encoding[] = "nv12";
const auto raw_size = width * height * 3 / 2;
const auto alloc_size =
qrb_ros::transport::image_utils::get_image_align_size(width, height,
encoding);
std::vector<std::uint8_t> data(raw_size);
for (std::size_t i = 0; i < data.size(); ++i)
data[i] = static_cast<std::uint8_t>(i % 251);
auto dmabuf =
lib_mem_dmabuf::DmaBuffer::alloc(alloc_size, "/dev/dma_heap/system");
if (!dmabuf || !qrb_ros::transport::image_utils::save_image_to_dmabuf(
dmabuf, data.data(), width, height, width, encoding,
true)) {
RCLCPP_ERROR(get_logger(), "failed to allocate or fill DMA-BUF");
rclcpp::shutdown();
return;
auto message = std::make_unique<Image>();
message->header.stamp = now();
message->header.frame_id = "qrb_transport_test";
message->width = width;
message->height = height;
message->encoding = encoding;
message->dmabuf = std::move(dmabuf);
publisher_->publish(std::move(message));
RCLCPP_INFO(get_logger(), "published %dx%d NV12 DMA-BUF image", width,
height);
rclcpp::Publisher<Image>::SharedPtr publisher_;
rclcpp::TimerBase::SharedPtr timer_;
class SubscriberNode : public rclcpp::Node {
public:
SubscriberNode() : Node("qrb_transport_test_subscriber") {
subscription_ = create_subscription<Image>(
"qrb_transport_test/image", 10,
[this](const std::shared_ptr<Image> message) { receive_image(message); });
private:
void receive_image(const std::shared_ptr<Image> &message) {
const auto raw_size = message->width * message->height * 3 / 2;
std::vector<char> data(raw_size);
const bool read_ok =
message->dmabuf &&
qrb_ros::transport::image_utils::read_image_from_dmabuf(
message->dmabuf, data.data(), message->width, message->height,
message->width, message->encoding, true);
bool content_ok = read_ok;
for (std::size_t i = 0; content_ok && i < data.size(); ++i)
content_ok = static_cast<std::uint8_t>(data[i]) ==
if (message->width == 64 && message->height == 48 &&
message->encoding == "nv12" && content_ok) {
RCLCPP_INFO(get_logger(), "PASS: received and verified %zu image bytes",
data.size());
} else {
RCLCPP_ERROR(get_logger(), "FAIL: invalid metadata or DMA-BUF content");
rclcpp::shutdown();
rclcpp::Subscription<Image>::SharedPtr subscription_;
int main(int argc, char **argv) {
rclcpp::init(argc, argv);
if (argc != 2 ||
(std::string(argv[1]) != "pub" && std::string(argv[1]) != "sub")) {
RCLCPP_ERROR(rclcpp::get_logger("qrb_transport_test"),
"usage: image_transport_test pub|sub");
return 2;
if (std::string(argv[1]) == "pub")
rclcpp::spin(std::make_shared<PublisherNode>());
else
rclcpp::spin(std::make_shared<SubscriberNode>());
rclcpp::shutdown();
return 0;
EOF
构建​
cd [your_workspace]
colcon build
运行​
终端 1 — 订阅者:
source [your_workspace]/install/setup.bash
ros2 run qrb_transport_test image_transport_test sub
终端 2 — 发布者:
ros2 run qrb_transport_test image_transport_test pub
预期输出​
终端 1:
[INFO] [qrb_transport_test_subscriber]: PASS: received and verified 4608 image bytes
终端 2:
[INFO] [qrb_transport_test_publisher]: published 64x48 NV12 DMA-BUF image
方式二:官方源码构建​
克隆官方仓库并构建,使用内置的测试组件验证。
构建​
git clone https://github.com/qualcomm-qrb-ros/qrb_ros_transport.git [your_transport_src]
colcon build --base-paths [your_transport_src]
准备测试数据​
生成 64×48 NV12 随机图像文件:
head -c 4608 /dev/urandom > [your_data_dir]/input_64x48_nv12.yuv
运行​
终端 1 — 订阅者(测量 FPS 和延迟):
ros2 component standalone qrb_ros_transport_test qrb_ros::transport::TestSubComponent \
-p topic_name:=official_image
终端 2 — 落盘组件(将收到的 DMA-BUF 写入文件):
ros2 component standalone qrb_ros_transport_test qrb_ros::transport::TestDumpComponent \
-p topic_name:=official_image \
-p dump_file:=[your_data_dir]/output_64x48_nv12.yuv
终端 3 — 发布者(读取文件并发布 DMA-BUF 消息):
ros2 component standalone qrb_ros_transport_test qrb_ros::transport::TestPubComponent \
-p input:=[your_data_dir]/input_64x48_nv12.yuv \
-p width:=64 \
-p height:=48 \
-p encoding:=nv12 \
-p fps:=30
预期输出​
终端 1 约 5 秒后打印 fps: ~30, latency: ~1.68 ms。终端 2 打印 dump success。
