PCIe E Key
支持的配件​
WIFI & BT 支持模块列表​
NO.ModelChipWiFiBTWIFI ThroughputRemark
1ROCK Pi Wireless Module A1 (SDIO+UART) --- AP6236BCM43436B02.4G4.2up:23.5 Mbits/sec down:40.4 Mbits/sec
2ROCK Pi Wireless Module A2 (SDIO+UART) --- AP6256BCM434562.4G&5G5.0up:196 Mbits/sec down: 187 Mbits/sec
3ROCK Pi Wireless Module A3 (SDIO+UART) --- AP6398SBCM435982.4G&5G5.0up:336 Mbits/sec down: 315 Mbits/sec
4ROCK Pi Wireless Module A6s (SDIO+UART) --- AP6275SBCM437522.4G&5G5.0up:234 Mbits/sec down: 273 Mbits/sec
5Radxa wireless A8RTL8852BE2.4G&5G&WIFI65.0up:600Mbits/sec down:900 Mbits/sec
6Intel 0MHK36 (PCIE+USB)Intel 31652.4G&5G4.2up:283 Mbits/sec down: 334 Mbits/sec
7Intel 7265NGW (PCIE+USB)Intel 72652.4G&5G4.2up:363 Mbits/sec down: 619 Mbits/sec
8Intel AX210 (PCIE+USB)Intel AX210WiFi 65.2up: 859 Mbits/sec down: 813 Mbits/sec
  • WIFI 的使用
    1. 首先进入 ROOT 用户模式
    radxa@rock-3b:~$ sudo su
    1. 打开 WIFI
    root@rock-3b:/home/radxa# nmcli r wifi on
    1. 扫描 WIFI
    root@rock-3b:/home/radxa# nmcli dev wifi
    1. 连接 WIFI 网络
    root@rock-3b:/home/radxa# nmcli dev wifi connect "wifi_name" password
    "wifi_password"
  • 蓝牙的使用
    1. 如果使用 Radxa 无线 A8 模块,必须添加以下黑名单才能使 BT 正常工作
    root@rock-3b:/home/radxa# cat /etc/modprobe.d/blacklist.conf blacklist
    pgdrv blacklist btusb blacklist btrtl blacklist btbcm blacklist btintel
    root@rock-3b:~# reboot
    1. Radxa APT 包括用于Broadcom无线模块的broadcom-wifibt-firmware软件包和用于Intel无线模块的intel-wifibt-firmware软件包。需要下载相应的软件包
    root@rock-3b:/home/radxa# apt-get update -y root@rock-3b
    :/home/radxa# apt-get install -y broadcom-wifibt-firmware intel-wifibt-firmware
    1. 测试蓝牙模块的状态并检查蓝牙设备
    root@rock-3b:/home/radxa# systemctl status bluetooth
    1. 运行蓝牙设备
    root@rock-3b:/home/radxa# systemctl start bluetooth
    1. 检测蓝牙设备
    root@rock-3b:/home/radxa# hciconfig hci0: Type: Primary Bus: UART BD
    Address: 10:2C:6B:49:D5:53 ACL MTU: 1021:8 SCO MTU: 64:1 UP RUNNING RX
    bytes:850 acl:0 sco:0 events:58 errors:0 TX bytes:2814 acl:0 sco:0
    commands:58 errors:0
    1. 测试:连接蓝牙音箱,首先安装 pulseaudio
    root@rock-3b:/home/radxa# apt-get install -y
    pulseaudio-module-bluetooth pulseaudio
    1. 运行 pulseaudio
    root@rock-3b:/home/radxa# pulseaudio --start
    1. 使用 pulseaudio 连接
    root@rock-3b:/home/radxa# bluetoothctl [bluetooth]# default-agent
    [bluetooth]# power on [bluetooth]# scan on [bluetooth]# trust
    41:42:1A:8D:A9:65 #BT-280 [bluetooth]# pair 41:42:1A:8D:A9:65 [bluetooth]#
    connect 41:42:1A:8D:A9:65
    1. 现在您可以听音乐了
