硬件接口说明
芯片框图​
rk3588 system diagram
实物照片​
rock 5b overview
接口详情​
eMMC​
NamePin#Pin#Name
GND134GND
EMMC_D5233eMMC_D6
GND332GND
EMMC_D4431eMMC_D7
GND530GND
EMMC_D0629eMMC_D1
GND728GND
EMMC_CLK827eMMC_D2
GND926GND
EMMC_D31025eMMC_CMD
GND1124GND
EMMC_RSTN1223VCC_3V3_S3
GND1322VCC_3V3_S3
GND1421VCC_1V8_S3
eMMC_DATA_STROBE1520VCC_1V8_S3
GND1619GND
GND1718GND
GND
GND35GND
GND36GND
GND37GND
GND38GND
GND39GND
GND40GND
GND41GND
GND42GND
GND43GND
GND44GND
GND45GND
GND46GND
GND47GND
GND48GND
GND49GND
GPIO​
  • GPIO 电压
GPIO电压最高
所有的GPIO3.3V3.63V
SARADC_IN41.8V1.98V
  • GPIO Pinout
GPIO numberFunction8Function7Function6Function5Function4Function3Function2Function1Pin#Pin#Function1Function2Function3Function4Function5Function6Function7Function8GPIO number
+3.3V
1
2
+5.0V
139I2S1_SDO2_M0I2C7_SDA_M3UART8_CTSN_M0PWM15_IR_M1GPIO4_B3
3
4
+5.0V
138I2S1_SDO1_M0I2C7_SCL_M3UART8_RTSN_M0PWM14_M1GPIO4_B2
5
6
GND
115SPI1_CS1_M1I2C8_SDA_M4UART7_CTSN_M1PWM15_IR_M0GPIO3_C3
7
8
GPIO0_B5
UART2_TX_M0
I2C1_SCL_M0I2S1_MCLK_M113
GND
9
10
GPIO0_B6
UART2_RX_M0
I2C1_SDA_M0I2S1_SCLK_M114
113SPI1_CLK_M1UART7_RX_M1GPIO3_C1
11
12
GPIO3_B5PWM12_M0UART3_TX_M1I2S2_SCLK_M1109
111SPI1_MOSI_M1I2C3_SCL_M1GPIO3_B7
13
14
GND
112SPI1_MISO_M1I2C3_SDA_M1UART7_TX_M1GPIO3_C0
15
16
GPIO3_A4100
+3.3V
17
18
GPIO4_C4PWM5_M2SPI3_MISO_M0148
42SPI0_MOSI_M2UART4_RX_M2GPIO1_B2
19
20
GND
41SPI0_MISO_M2GPIO1_B1
21
22
SARADC_IN4
43SPI0_CLK_M2UART4_TX_M2GPIO1_B3
23
24
GPIO1_B4UART7_RX_M2SPI0_CS0_M244
GND
25
26
GPIO1_B5UART7_TX_M2SPI0_CS1_M245
150SPI3_CLK_M0I2C0_SDA_M1PWM7_IR_M3GPIO4_C6
27
28
GPIO4_C5PWM6_M2I2C0_SCL_M1SPI3_MOSI_M0149
63UART1_CTSN_M1PWM15_IR_M3GPIO1_D7
29
30
GND
47SPDIF_TX_M0UART1_RX_M1PWM13_M2GPIO1_B7
31
32
GPIO3_C2PWM14_M0UART7_RTSN_M1I2C8_SCL_M4SPI1_CS0_M1114
103PWM8_M0GPIO3_A7
33
34
GND
110I2S2_LRCK_M1UART3_RX_M1PWM13_M0GPIO3_B6
35
36
GPIO3_B1PWM2_M1UART2_TX_M2105
GPIO0_A0
37
38
GPIO3_B2PWM3_IR_M1UART2_RX_M2I2S2_SDI_M1106
GND
39
40
GPIO3_B3UART2_RTSNI2S2_SDO_M1107
40-pin 排针不提供开机 / 唤醒信号
ROCK 5B/5B+ 的 40-pin 排针没有引出 PMIC 的开机信号(PWRON),也没有引出唤醒信号,因此无法通过 40-pin 上的引脚实现外部硬件开机或唤醒。该触发信号只存在于 PMIC 部分电路,没有连接到 40-pin 排针。
如果需要由外部电路控制开机,可以控制输入到板子的 5V / USB-PD 电源;给 40-pin 的 5V(PIN 2 / PIN 4)通电可以让板子启动,但这属于电源上电,并不是由引脚控制的开机触发。
Gigabit Ethernet​
  • ROCK 5B/5B+
Pin#NamePin#Name
1MDI0+2MDI0-
3MDI1+4GND
5GND6MDI1-
7MDI2+8MDI2-
9MDI3+10MDI3-
11GND12GND
13GND14GND
15LED016LED1
17V3P3A18LED2
19GND20GND
Maskrom Button​
NamePin#Pin#Name
GND12BOOT_SARADC_IN0
MIPI CSI​
Pin#NamePin#Name
1GND17MIPI_CSI0_RX_CLK0N
2MIPI_CSI0_RX_D3N18MIPI_CSI0_RX_CLK0P
3MIPI_CSI0_RX_D3P19GND
4GND20MIPI_CAM3_CLKOUT
5MIPI_CSI0_RX_D2N21GND
6MIPI_CSI0_RX_D2P22MIPI_CAM1_CLKOUT
7GND23MIPI_CSI0_PDN0_H
8MIPI_CSI0_RX_CLK1N24I2C3_SCL_M0_MIPI
9MIPI_CSI0_RX_CLK1P25I2C3_SDA_M0_MIPI
10GND26MIPI_CSI0_PDN1_H
11MIPI_CSI0_RX_D1N27CM_RST_L
12MIPI_CSI0_RX_D1P28VCC_3V3_S3
13GND29VCC_3V3_S3
14MIPI_CSI0_RX_D0N30VCC5V0_SYS
15MIPI_CSI0_RX_D0P31VCC5V0_SYS
16GND
MIPI DSI​
Pin#NamePin#Name
1LCD_3V321GND
2VCC_1V8_S022GND
3GPIO0-A023TP_RST_L
4LCD_RESET24LCD_3V3
5NC25TP_INT_L
6GND26I2C6_SDA_M0
7MIPI_DPHY1_TX_D0N27I2C6_SCL_M0
8MIPI_DPHY1_TX_D0P28GND
9GND29GND
10MIPI_DPHY1_TX_D1N30LCD_3V3
11MIPI_DPHY1_TX_D1P31LCD_3V3
12GND32GND
13MIPI_DPHY1_TX_CLKN33GND
14MIPI_DPHY1_TX_CLKP34VCC_LEDK
15GND35VCC_LEDK
16MIPI_DPHY1_TX_D2N36NC
17MIPI_DPHY1_TX_D2P37NC
18GND38VCC_LEDA
19MIPI_DPHY1_TX_D3N39VCC_LEDA
20MIPI_DPHY1_TX_D3P40GND
41GND
PCIe​
  • PCIe B Key
ROCK 5B 没有 PCIe B Key
  • PCIe E Key
Pin#NamePin#NamePin#NamePin#Name
1GND21WIFI_WAKE_HOST_H_GPIO3_D549PCIE20_REFCLKN69GND
2VCC3V3_WF22UART1_RX_M050WIFIBT_32KIN_1T1R70BT_WAKE
3USB2_M2_DP23WIFI_REG_ON51GND71NC
4VCC3V3_WF32UART1_TX_M052PCIE_PERSTN72VCC3V3_WF
5USB2_M2_DM33GND53PCIE_CLKREQN73NC
6WIFI_LED34UART1_CTS_M54HOST_WAKE_BT_H74VCC3V3_WF
7GND35PCIE_TXP55PCIE_WAKEN75GND
8PCM_CLK/I2S_SCK36UART1_RTS_M56BT_REG_ON_H76GND
9SDIO_CLK37PCIE_TXN57GND77GND
10PCM_SYNC/I2S_WS38NC58I2C4_SDA_M178NC
11SDMMC2_CMD_M039GND59NC79NC
12PCM_OUT/I2S SD_OUT40NC60I2C4_SCL_M1
13SDMMC2_D0_M041PCIE20_RXP61NC
14PCM_IN/I2S SD_IN42BT_REG_NO62NC
15SDMMC2_D1_M043PCIE20_RXN63GND
16NC44NC64NC
17SDMMC2_D2_M045GND65NC
18GND46NC66NC
19SDMMC2_D3_M047PCIE20_REFC67NC
20BT_WAKE_HOST_H_GPIO4_B448NC68NC
  • PCIe M Key
Pin#NamePin#Name
1GND2VCC3V3_PCIE30
3GND4VCC3V3_PCIE30
5PCIE30_PORT1_RX3N6NC
7PCIE30_PORT1_RX3P8NC
9GND10NC
11PCIE30_PORT1_TX3N12VCC3V3_PCIE30
13PCIE30_PORT1_TX3P14VCC3V3_PCIE30
15GND16VCC3V3_PCIE30
17PCIE30_PORT1_RX2N18VCC3V3_PCIE30
19PCIE30_PORT1_RX2P20NC
21GND22NC
23PCIE30_PORT1_TX2N24NC
25PCIE30_PORT1_TX2P26NC
27GND28NC
29PCIE30_PORT0_RX1N30NC
31PCIE30_PORT0_RX1P32NC
33GND34NC
35PCIE30_PORT0_TX1N36NC
37PCIE30_PORT0_TX1P38NC
39GND40NC
41PCIE30_PORT0_RX0N42NC
43PCIE30_PORT0_RX0P44CLK_3P
45GND46CLK_3N
47PCIE30_PORT0_TX0N48NC
49PCIE30_PORT0_TX0P50PCIE30X4_PERSTn_M1_L
51GND52PCIE30X4_CLKREQn_M1_L
53PCIE30_REFCLKN_SLOT54PCIE30X4_WAKEn_M1_L
55PCIE30_REFCLKP_SLOT56NC
57GND58NC
67NC68NC
69NC70VCC3V3_PCIE30
71GND72VCC3V3_PCIE30
73GND74VCC3V3_PCIE30
75GND76GND
77GND
POE​
NamePin#Pin#Name
TR242TR0
TR331TR1
TF Card Slot​
Pin#Name
1SDMMC0_D2
2SDMMC0_D3
3SDMMC0_CMD
4VCC3V3_SYS
5SDMMC0_CLK
6GND
7SDMMC0_D0
8SDMMC0_D1
9SDMMC0_DET_L
10GND
11GND
12GND
13GND
