Quick start
Physical Image​
Currently the E52C is available in a variety of configurations, with case, bare board, with on-board EMMC, and without on-board EMMC, so please be careful to distinguish your product model before operation.
radxa-e52c pack
To start the Radxa E52C, you need the following equipment::
  • 1x 5V/3A power adapter (E52C can only be powered by 5V, you can use a PD power supply that supports 5V), For more details on power supply, please refer to power-supply.
  • 2x USB TYPE-A to TYPE-C cable to power and view log output and access the system.
  • 2x Ethernet network cable.
Installing the operating system​
E52C with onBoard EMMC is equipped with a pre-installed system istoreos, no need to install os.
Wiring and powering up​
Connect WAN and LAN,then power on, the system will boot automatically.
e52c connect
Login​
Login Via Browser​
If the LAN port is connected to the PC, you can login to the iStoreOS system background through the browser via the iStoreOS default ip 192.168.100.1.
The default username of the iStoreOS background is root, and the password is password.
e52c-istoreos e52c-istoreos
Login Via Serial port​
  1. Connect the TYPE-A port of the USB TYPE-A to TYPE-C cable to the computer and the TYPE-C port to the Radxa E52C debug port, and set the baud rate to 1500000.
radxa-e52c pack
  1. Connect the TYPE-A port of the USB TYPE-A to TYPE-C cable to the computer, and the TYPE-C port to the Radxa E52C debug port, and set the baud rate to 1500000.
radxa-e52c pack
  1. Plug the power adapter into the Radxa E52C's power connector. The device will power up and start, the system status light will be on.
radxa-e52c pack
  1. If you are on windows system, make sure the CH340 driver is installed on your computer.
    Connect the TYPE-A port of the USB TYPE-A to TYPE-C cable to the computer, and the TYPE-C port to the Radxa E52C debug port, and check whether there is a CH340 driver in the device manager of the computer.
    radxa-e52c pack
    You can see the USB-SERIAL CH340 in the picture above, it means there is a driver, if not, please install the CH340 driver.
  2. Use the serial port tool
Windows​
Putty is a serial port tool that can be used on Windows and supports multiple baud rates. Here is how to use Putty to connect to a serial port.
  1. Download Putty and install it.
  2. Plug the USB end of the USB to TTL serial cable into the PC and check the Device Manager to find the COM number. Here we assume it is COM3.
  3. Open Putty and set it up as follows:
  • Select Session in the left column, set the serial line to COM3, the baud rate to 1500000, and the connection type to Serial.
  • Write radxa-e52c in the Saved Sessions column and press Save.
Putty
  1. Select Serial at the bottom of the left column and configure it with the following parameters:
Putty
  1. After setting, click Open to open the serial port, make sure the TTL port is correctly connected, and then turn on the power of the motherboard.
Login Via SSH​
  1. Connect the network cable to the WAN or LAN port, the following is an example of how to access the device by SSH using the WAN port
radxa-e52c pack
radxa-e52c pack
  1. When the system is up, the system status light will blink and the WAN port light will also be on
radxa-e52c pack
  1. Use Angryip to find IP
    This method can be used to find IP address when you can't directly operate the motherboard to get no screen or remote IP address.
    The default ip address of the iStoreOS system is 192.168.100.1.
    If the user has changed it himself, he can use the Angryip tool to look it up.
    • First of all, the host needs to download Angryip, and then make sure the host and motherboard are in the same LAN.
    • Open Angryip, select the IP range 192.168.2.0 - 192.168.2.255 (select the network segment where the host computer and motherboard are located), click Start, as shown in the figure.
    • Angryip
    • Ctrl + F Look for the e52c keyword to find the IP address of the motherboard.
  2. Connecting to Radxa E52C via SSH
System login​
Debian
Default UserName: radxa Default Password: radxa
iStoreOS
Default UserName: root Default Password: password
istoreos expansion​
Because the default file system size of iStoreOS is only 2GB, if you need to expand it, please follow the tips in the photos below:
e52c-istoreos e52c-istoreos e52c-istoreos e52c-istoreos e52c-istoreos e52c-istoreos e52c-istoreos
