System Installation
assembly
First, align the four mounting holes on the core board with the four mounting holes on the io board. Then, gently press down one side to about halfway, followed by pressing the other side to halfway as well. After confirming that all slots are aligned, press down each side to the bottom in sequence.
Note: When pressing, do not forcefully press down on the suspended area in the middle, as this may cause stress on the PCB, leading to component loosening or damage, such as DDR loosening or resistor breakage.
Precautions
Installation
This document introduces how to install Radxa OS image to Radxa CM5.
CM5 can boot from microSD card or eMMC, so install os on microSD card or eMMC based on your choose.
Preparation
Prepare the installation media
  • microSD card (recommended class10 rating or higher)
  • USB card reader
Prepare the image file
Please go to Download Summary to download image.
System installation
  1. Download Etcher ROCK5A via Etcher 01
  2. Open Etcher and flash the prepared OS image to the microSD card. In the Etcher window, click Flash from file to select the OS image you just downloaded. ROCK5A via Etcher 02
  3. In the Etcher window, click Select target. ROCK5A via Etcher 03
  4. In the Etcher window, click Flash! and wait for a progress bar to be flushed. ROCK5A via Etcher 04
  5. In the Etcher window, Flash Complete! will be displayed when the flash is successful. ROCK5A via Etcher 05
System startup
Starting CM5 IO
  1. Insert the microSD card with the operating system installed.
  2. Power up the CM5 IO via the DC 12V power adapter.
  3. The CM5 IO will boot up with the green power LED on, and the blue LED will start blinking when it enters the system.
Frequently Asked Questions
Reference
Login
There are two default users for official system.
  1. username: radxa password: radxa
  2. username: rock password: rock
More info please refer to RadxaOS
