U-boot Development
Using bsp​
bsp is a set of tools provided by Radxa to quickly build U-Boot Kernels. It is very easy to build your own U-Boot and Kernel using bsp.
The following shows you how to build a kernel with bsp using Radxa ROCK 5B as an example.
bsp environment configuration​
The following is the recommended environment for bsp.
Hardware: x86_64 PC recommended
System: Ubuntu 22.04 or Debian 12
installs dependencies​
# Podman (recommended)
# Docker
# sudo apt install docker.io
# Optional dependencies for minor features
Getting the code​
bsp uses the git submodule. Therefore, use the following command to get the code:
Understanding bsp usage​
Once you have the bsp code on your machine, you can run bsp to see the built-in help:
cd bsp
. /bsp
Build U-Boot​
Running ./bsp will show you all the parameters and their explanations, and you can see the command bsp [options] <linux|u-boot> <profile> [product] from the prompt.
Taking Radxa ROCK 5B as an example, the U-Boot profile is "rk2410". The following are profiles for other products:
productprofileproductprofileproductprofileproductprofile
rock-2rk2410radxa-e54crk2410radxa-zerolatestrock-pi-elatest
radxa-e24c-spirk2410radxa-nx5-iork2410radxa-zero-2prolatestrock-4selatest
rock-5-itxrk2410radxa-cm4-rpi-cm4-iork2410radxa-cm3-iolatestrock-pi-4a-pluslatest
rock-5ark2410radxa-cm5-iork2410radxa-cm3-rpi-cm4-iolatestrock-pi-4b-pluslatest
rock-5brk2410radxa-cm5-rpi-cm4-iork2410radxa-cm3-sodimm-iolatestrock-4c-pluslatest
rock-5b-plusrk2410radxa-cm3j-rpi-cm4-iork2410radxa-e23latestrock-pi-4alatest
rock-5crk2410radxa-e25rknextradxa-zero3rk2410rock-pi-4blatest
rock-5drk2410radxa-cm3i-iorknextrock-3alatestrock-pi-4clatest
rock-5trk2410rock-3blatestrock-4-core-iolatest
rock-5a-spirk2410rock-3clatest
rock-5c-spirk2410rock-pi-n10latest
rock-5d-spirk2410rock-s0latest
radxa-e52crk2410rock-pi-slatest
radxa-rk3576rk2410
If the product model is not found in the table, select the corresponding option based on your product's SoC model.
Example: Radxa CM4 / NX4 and ROCK 4D use the Rockchip RK3576 SoC. According to the table, select rk2410 as the profile parameter for radxa-rk3576.
Then fill in the profile parameter of the bsp command with the product's corresponding profile: rk2410 to pull and configure the code, for example, using rock-5b as the example:
./bsp u-boot rk2410 rock-5b --no-build
# `--no-build` only configure the code without compile
The path to the U-Boot source code is located in .src/u-boot in the bsp directory, and the U-Boot can be built again after modifying the kernel source code:
cd bsp
./bsp --no-prepare-source u-boot rk2410 rock-5b -r 999
# Parameter description:
# `--no-prepare-source` # This parameter is not needed for first time compilation, it is added to compile with local modifications, if this parameter is not added, the latest code will be synchronized from the Radxa kernel repository and overwrite the local modifications.
# `-r 999` # Specify the kernel version as 999 for priority use.
After compilation, many deb packages will be generated in the current directory, you just need to install the following deb packages.
u-boot-rk2410_2017.09-999_arm64.deb
Copy the above one deb packages to the board and install them with the dpkg command to complete the U-Boot installation.
sudo dpkg -i u-boot-rk2410_2017.09-999_arm64.deb
After the installation is complete, you need to flash U-Boot to the boot media
cd /usr/lib/u-boot/rock-5b/                     # rock-5b is your current model, you need to choose according to the actual model used
sudo ./setup.sh update_bootloader /dev/mmcblk1 # /dev/mmcblk1 is your current boot media, you need to choose according to the actual device used
sudo reboot
After reboot, you can observe the U-Boot boot log to see if U-Boot has been updated successfully.
Compile manually​
bsp is the only compilation method currently being maintained, and it makes additional changes to the source code when compiling. If you want to build on our official releases, you should at least use bsp to download and configure the code.
If you want to build with a custom make command, please refer to the Prepare working tree section to configure the code.
Refer to​
