Quick Start
Physical Image​
Currently, E20C has multiple configurations, including with casing, bare board, with onboard EMMC, and with empty EMMC soldering. Please distinguish your product model before operation.
radxa-e20c pack
To start the Radxa E20C, you need the following equipment:
  • 1x 5V/2A power adapter (E20C can only be powered by 5V, you can use a PD power supply that supports 5V), For more details on power supply, please refer to power-supply.
  • 2x USB TYPE-A to TYPE-C cable to power and view log output and access the system.
  • 2x Ethernet network cable.
Installing the Operating System​
E20C with onBoard EMMC is equipped with a pre-installed system istoreos, no need to install os.
Wiring and Powering Up​
Connect WAN and LAN,then power on, the system will boot automatically.
e20c connect
Login​
Login Via Browser​
If the LAN port is connected to the PC, you can login to the iStoreOS system background through the browser via the iStoreOS default ip 192.168.100.1, The default username of the iStoreOS background is root, and the password is password.
e20c-istoreos e20c-istoreos
Login Via Serial Port​
  1. Connect the TYPE-A port of the USB Type-A to Type-C cable to the computer, and the Type-C port to the Radxa E20C debug port, and set the baud rate to 1500000.
radxa-e20c pack
  1. Plug the power adapter into the Radxa E20C's power connector. The device will power up and start, the system status light will be on.
radxa-e20c pack
  1. After the system is up, the system status light will flash
radxa-e20c pack
  1. Use the serial port tool
Putty is a serial port tool that can be used on Windows and supports multiple baud rates. Here is how to use Putty to connect to a serial port.
  1. Download Putty and install it.
  2. Use the USB Type-A to Type-C cable's Type-A port to connect to the computer, and the Type-C port to connect to the Radxa E20C debug port, check the computer's Device Manager interface to find the COM port number. Here we assume it is COM4.
radxa-e20c pack
Driver Installation
If you cannot properly recognize the serial device, make sure the computer has the CH340 driver installed
If the driver is not installed, please install the CH340 driver
  1. Open Putty and set it up as follows:
  • Select Session in the left column, set the serial line to COM3, the baud rate to 1500000, and the connection type to Serial.
  • Write radxa-e20c in the Saved Sessions column and press Save.
Putty
  1. Select Serial at the bottom of the left column and configure it with the following parameters:
Putty
  1. After setting, click Open to open the serial port, make sure the TTL port is correctly connected, and then turn on the power of the motherboard.
Login Via SSH​
  1. Connect the network cable to the WAN or LAN port, the following is an example of how to access the device by SSH using the WAN port
radxa-e20c pack
radxa-e20c pack
  1. When the system is up, the system status light will blink and the WAN port light will also be on
radxa-e20c pack
  1. Find IP
The iStoreOS system default IP address is 192.168.100.1
But if the user modifies it themselves, they can use the Angryip tool to query it
  • First, the host needs to download Angryip, and then make sure the host and motherboard are in the same LAN.
  • Open Angryip, select the IP range 192.168.2.0 - 192.168.2.255 (select the network segment where the host computer and motherboard are located), click Start, as shown in the figure.
  • Angryip
  • Ctrl + F Look for the 2a keyword to find the IP address of the motherboard.
  1. SSH connection to Radxa E20C
Default username: root Default password: password
iStoreOS Expansion​
Please follow the instructions in the picture to expand/scale up the capacity.
e20c-istoreos e20c-istoreos e20c-istoreos e20c-istoreos e20c-istoreos e20c-istoreos e20c-istoreos
