Clear eMMC or SPI Flash
Enter to Maskrom Mode
- ROCK 5B
- ROCK 5B+
- Remove the microSD card and power cable.
- Press and hold the Maskrom button.
- Insert the USB A-C cable into the Type-C port of ROCK 5B, with the other end plugged into the computer. This should normally put it into Maskrom mode.
- Insert the USB A-C cable into the Type-C port of ROCK 5B+, with the other end plugged into the computer. Power on the ROCK 5B+; this should normally put it into Maskrom mode.
Erase eMMC
- Linux/MacOS
- Windows
Generate zero.img
dd if=/dev/zero of=./zero.img bs=1M count=64
Make sure the host recognises Maskrom
sudo rkdeveloptool ld
DevNo=1 Vid=0x2207,Pid=0x350a,LocationID=109 Maskrom -
Flash Loader
sudo rkdeveloptool db rk3588_spl_loader_v1.15.113.bin
- Erase eMMC
sudo rkdeveloptool wl 0 zero.img
- Reboot
sudo rkdeveloptool rd
Open the RkDevTool tool and we'll use the RkDevTool to erase
Click on the button to the left of "Download" to select the Loader
Click "Download" to flash the Loader (Go to download page to download file)
Click "ReadCapability" to get current storage
Click on "Switch storage" to switch the storage to eMMC
Click the "EraseAll" button to erase the eMMC
Click "ResetDevice"
Erase SPI Flash
- Linux/MacOS
- Windows
Generate zero.img
Flash Loader
- Erase SPI Flash
sudo rkdeveloptool ef
- Reboot
Click on "Switch storage" to switch the storage to SPINOR
Click the "EraseAll" button to erase the SPI Flash
Click "ResetDevice"
