Install System to MicroSD Card
File Download
Please download the related Images refer to Summary of resource downloads
Prepare MicroSD Card
Insert the MicroSD card into an SD card reader, then plug the reader into a USB port on your PC.
Image Burning
Balena Etcher is a cross-platform and user friendly image file burning tool that we recommend you use.
- Download Etcher and install it.
- Windows
- Linux
Please download balenaEtcher-Setup-1.18.11.exe After the download is complete, there is no need to perform any additional actions. After downloading, you can double click it to open it without any additional operation.
Please download balena-etcher_1.18.11_amd64.deb. Once the download is complete, please install it by executing the following command in the terminal:
sudo dpkg -i balena-etcher_1.18.11_amd64.deb
Open Etcher
Open Etcher and click
Flash from file
to select the image to write to. -
Click
Select target
to select the device, please select carefully. -
Click
Flash!
Start writing and wait for the write progress bar to complete. -
When writing the image successfully, Etcher will display
Flash Complete!
If there is an error in flashing, please try again.
Start the System
After successfully burning the MicroSD card following the steps above, insert the MicroSD card into the MicroSD card slot (as shown below), power on, and the system will start with the desktop displayed on HDMI.
Log In to the System
After the system boots up, log in using the username 'radxa' and password 'radxa'.
The entire process from powering on to booting into the desktop takes approximately 40 seconds.
