Maskrom mode
The Radxa CM5 supports Maskrom mode, a special mode of operation in which the CPU receives commands through the USB OTG port. This guide will instruct you how to put the Radxa CM5 into Maskrom mode for operation.
Preparation
  • Radxa CM5 SBC
  • 12V DC power adapter
  • USB-A to USB-C adapter cable
Steps
  1. Installation and Use of Burning Tools
    RKDevTool is used to burn images under Windows, for installation and tutorials see: RKDevTool Guide.
  2. Remove the microSD card and other storage devices.
  3. Connect the USB-A end of the USB-A to USB-C adapter cable to the host computer port and the USB-C end to the OTG port (type-c port next to the headphone port) of the Radxa CM5, as shown below
    OTG connection
  4. Press and hold the Maskrom button on the CM5.
    Long press maskrom key
  5. Power on and boot up, then you can use the corresponding tool to check whether you have successfully entered Maskrom mode, the following is an example of correct entry
    Connect SPI Pin
