40-PIN Function Test
GPIO
GPIO Introduction
General Purpose Inputs/Outputs (GPIOs) are non-dedicated digital signal pins on the circuit board of an integrated circuit or electronic circuit (e.g., MCU/MPU) that can be used as inputs or outputs, or both, and can be controlled by software.
Preparations
  • One Radxa ROCK 5C
  • One LED
Connection
Connecting PIN_3 of Radxa ROCK 5C as shown
gpio connection
Test
Input Tests
Ground 3 or connect to 3.3V,
  radxa@rock-5c:~$ gpioget gpiochipundefined undefined
This command outputs 0 if ground is connected and 1 if 3.3V is connected.
Output Test
  radxa@rock-5c:~$ sudo gpioset -m signal $(sudo gpiofind PIN_3)=0 # Output low, Led off
  radxa@rock-5c:~$ sudo gpioset -m signal $(sudo gpiofind PIN_3)=1 # Output high, Led on
The same GPIO cannot be used by two processes at the same time, otherwise it will indicate resource usage. Therefore, you need to wait for the first command to finish executing before you can execute the second command.
I2C
I2C 简介
I2C (Inter-Integrated Circuit; pronounced "eye-squared-see" or "eye-two-see"), also known as I2C or IIC, is a synchronous, multi-controller/multi-destination (historically known as master/slave), single-ended, serial communications bus invented by Philips Semiconductors in 1982.
Preparations
  • One Radxa ROCK 5C
  • One OLED
Enable Overlay
Please refer to Device Tree Configuration to enable I2C Related Overlay, eg: "Enable I2C8-M2".
Connection
Connect Radxa ROCK 5C and OLED as follows
Radxa ROCK 5C<-->OLED
PIN_5<-->SCL
PIN_3<-->SDA
PIN_1<-->VCC
PIN_9<-->GND
i2c connection
Test
  • Open a terminal and install the Python library python3-periphery by typing the following command in the terminal
  • Create a new Python file called Oled.py and paste the following code into it:
Oled.py
from periphery import I2C
import time
I2C_ADDR = 0x3c
I2C_BUS = "/dev/i2c-8"
i2c = I2C(I2C_BUS)
# SSD1306 init_cmds
init_cmds = [
0xAE, # Display off
0xB0, # Set page address
0x81, # Set contrast control
0xCF,
0xA1, # Set segment remap
0xA6, # Normal display
0xA8, # Set multiplex ratio
0x3F,
0xD3, # Set display offset
0x00,
0x80,
0xD9, # Set pre-charge period
0xF1,
0x12,
0x40,
0x14,
0xAF # Display on
for cmd in init_cmds:
def oled_clear():
for page in range(8):
for _ in range(128):
char_map = {
def string_to_bytes(string):
bytes_list = []
for char in string:
bytes_list.extend(char_map.get(char, [0x00] * 4))
bytes_list.append(0x00)
return bytes_list
oled_clear()
i2c.close()
This script is only an example, you need to modify the variable I2C_BUS according to the actual situation.
  • In a terminal, execute the following command to test
sudo python3 Oled.py
After executing the above command, Oled will display the characters "Hello, Radxa".
PWM
PWM Introduction
Pulse Width Modulation (PWM) is a modulation technique that produces variable width pulses to represent the amplitude of an analog input signal. For high amplitude signals, the output switching transistor is on more of the time, while for low amplitude signals, the output switching transistor is off more of the time.
Preparations
  • One Radxa ROCK 5C
  • One LED
Enable Overlay
Please refer to DeviceTree configuration to enable PWM-related Overlay.
eg: "Enable PWM0_M2.
Connection
As shown in the picture,connect Radxa ROCK 5C's 23
pwm connection
Test
  • Open a terminal and install the Python library for python3-periphery by typing the following command in the terminal
sudo apt-get install python3-periphery
  • Create a new Python file called Pwm_led_test.py and paste the following code into the file:
Pwm_led_test.py
#!/usr/bin/env python3 # -- encoding: utf-8 --
from periphery import PWM import time
step = 0.05 Range = int(1/0.05)
pwmchip = int(input("pwmchip:")) channel = int(input("channel:"))
pwm = PWM(pwmchip, channel)
try: pwm.frequency = 1e3 pwm.duty_cycle = 0.00 pwm.enable()
while True: for i in range(0,Range): time.sleep(step) pwm.duty_cycle = round(pwm.duty_cycle+step,2)
if pwm.duty_cycle == 1.5: time.sleep(1.5) for i in range(0,Range): time.sleep(step) pwm.duty_cycle = round(pwm.duty_cycle-step,2) except: print("Error !\n")
finally: pwm.duty_cycle = 1.0 pwm.close()
  radxa@rock-5c:~$ sudo python3 Pwm_led_test.py
  pwmchip:undefined
  channel:0
After executing the above commands, Led will have a gradient effect (dark to light, light to dark).
SPI
Introduction to SPI
The Serial Peripheral Interface (SPI) is the de facto standard for synchronous serial communication (there are many variants), primarily used for short-range wired communication between integrated circuits in embedded systems.
Preparation
  • One rock-5c
  • One female-to-female Dupont wire
Enable Overlay
Please refer to Device Tree configuration Enable SPIDEV Related Overlay, eg: "Enable spidev on SPI0-M2 over CS0"。
Connection
Short 29 and 31 as shown
spi connection
Test
  • Open a terminal and enter the following command in the terminal to install the compilation tool
sudo apt-get install build-essential
  • Create a new C file called spidev_test.c and paste the following code into the file:
spidev_test.c
* SPI testing utility (using spidev driver)
* Copyright (c) 2007 MontaVista Software, Inc.
* Copyright (c) 2007 Anton Vorontsov <avorontsov@ru.mvista.com>
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 2 of the License.
* Cross-compile with cross-gcc -I/path/to/cross-kernel/include
#include <stdint.h>
#include <unistd.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <getopt.h>
#include <fcntl.h>
#include <sys/ioctl.h>
#include <linux/ioctl.h>
#include <sys/stat.h>
#include <linux/types.h>
#include <linux/spi/spidev.h>
static void pabort(const char *s)
perror(s);
abort();
static const char *device = "/dev/spidev0.0";
static uint32_t mode;
static uint8_t bits = 8;
static char *input_file;
static char *output_file;
static uint16_t delay;
static int verbose;
uint8_t default_tx[] = {
0xFF FF FF FF FF FF,
0x40 00 00 00 00 95,
0xF0 0D,
char *input_tx;
char *prefix)
int i = 0;
unsigned char c;
printf("%s | ", prefix);
while (length-- > 0) {
printf("%02X ", *address++);
if (length == 0) {
while (i++ % line_size)
printf("__ ");
while (line < address) {
c = *line++;
printf("\n");
if (length > 0)
* Unescape - process hexadecimal escape character
* converts shell input "\x23" -> 0x23
static int unescape(char *_dst, char *_src)
int ret = 0;
int match;
char *src = _src;
char *dst = _dst;
unsigned int ch;
while (*src) {
if (!match)
src += 4;
*dst++ = (unsigned char)ch;
} else {
*dst++ = *src++;
ret++;
return ret;
int ret;
int out_fd;
.tx_buf = (unsigned long)tx,
.rx_buf = (unsigned long)rx,
.len = len,
.delay_usecs = delay,
.speed_hz = speed,
.bits_per_word = bits,
if (mode & SPI_TX_QUAD)
tr.tx_nbits = 4;
else if (mode & SPI_TX_DUAL)
tr.tx_nbits = 2;
if (mode & SPI_RX_QUAD)
tr.rx_nbits = 4;
else if (mode & SPI_RX_DUAL)
tr.rx_nbits = 2;
if (!(mode & SPI_LOOP)) {
tr.rx_buf = 0;
tr.tx_buf = 0;
if (ret < 1)
if (verbose)
hex_dump(tx, len, 32, "TX");
if (output_file) {
if (out_fd < 0)
ret = write(out_fd, rx, len);
if (ret != len)
close(out_fd);
if (verbose || !output_file)
hex_dump(rx, len, 32, "RX");
static void print_usage(const char *prog)
" -d --delay delay (usec)\n"
" -b --bpw bits per word\n"
" -l --loop loopback\n"
" -H --cpha clock phase\n"
" -O --cpol clock polarity\n"
" -2 --dual dual transfer\n"
exit(1);
static void parse_opts(int argc, char *argv[])
while (1) {
{ "device", 1, 0, 'D' },
{ "speed", 1, 0, 's' },
{ "delay", 1, 0, 'd' },
{ "bpw", 1, 0, 'b' },
{ "input", 1, 0, 'i' },
{ "output", 1, 0, 'o' },
{ "loop", 0, 0, 'l' },
{ "cpha", 0, 0, 'H' },
{ "cpol", 0, 0, 'O' },
{ "lsb", 0, 0, 'L' },
{ "cs-high", 0, 0, 'C' },
{ "3wire", 0, 0, '3' },
{ "no-cs", 0, 0, 'N' },
{ "ready", 0, 0, 'R' },
{ "dual", 0, 0, '2' },
{ "verbose", 0, 0, 'v' },
{ "quad", 0, 0, '4' },
{ NULL, 0, 0, 0 },
int c;
lopts, NULL);
if (c == -1)
break;
switch (c) {
case 'D':
device = optarg;
break;
case 's':
speed = atoi(optarg);
break;
case 'd':
delay = atoi(optarg);
break;
case 'b':
bits = atoi(optarg);
break;
case 'i':
input_file = optarg;
break;
case 'o':
output_file = optarg;
break;
case 'l':
mode |= SPI_LOOP;
break;
case 'H':
mode |= SPI_CPHA;
break;
case 'O':
mode |= SPI_CPOL;
break;
case 'L':
mode |= SPI_LSB_FIRST;
break;
case 'C':
mode |= SPI_CS_HIGH;
break;
case '3':
mode |= SPI_3WIRE;
break;
case 'N':
mode |= SPI_NO_CS;
break;
case 'v':
verbose = 1;
break;
case 'R':
mode |= SPI_READY;
break;
case 'p':
input_tx = optarg;
break;
case '2':
mode |= SPI_TX_DUAL;
break;
case '4':
mode |= SPI_TX_QUAD;
break;
default:
print_usage(argv[0]);
break;
if (mode & SPI_LOOP) {
mode |= SPI_RX_DUAL;
mode |= SPI_RX_QUAD;
size_t size = strlen(str);
uint8_t *tx;
uint8_t *rx;
tx = malloc(size);
if (!tx)
rx = malloc(size);
if (!rx)
transfer(fd, tx, rx, size);
free(rx);
free(tx);
ssize_t bytes;
struct stat sb;
int tx_fd;
uint8_t *tx;
uint8_t *rx;
if (tx_fd < 0)
tx = malloc(sb.st_size);
if (!tx)
rx = malloc(sb.st_size);
if (!rx)
if (bytes != sb.st_size)
free(rx);
free(tx);
close(tx_fd);
int main(int argc, char *argv[])
int ret = 0;
int fd;
parse_opts(argc, argv);
fd = open(device, O_RDWR);
if (fd < 0)
pabort("can't open device");
* spi mode
if (ret == -1)
pabort("can't set spi mode");
if (ret == -1)
pabort("can't get spi mode");
* bits per word
if (ret == -1)
if (ret == -1)
* max speed hz
if (ret == -1)
if (ret == -1)
if (input_tx && input_file)
if (input_tx)
else if (input_file)
else
close(fd);
return ret;
  • View added spidev devices
ls /dev/spidev*
  • Modify the line static const char *device = ‘/dev/spidev0.0’; according to the actual spidev device.
For example, if the actual spidev is /dev/spidev1.0, then static const char *device = ‘/dev/spidev1.0’;
  • In a terminal, compile by typing the following command
gcc spidev_test.c
  • In the terminal, enter the following command to test
sudo ./a.out
  • Check the output
If the output is consistent with default_tx (if the output is consistent with the following), then the spi loopback test was successful
spi mode: 0x0
bits per word: 8
RX | FF FF FF FF FF FF 40 00 00 00 00 95 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF F0 0D | ......@......................�.
UART
UART Introduction
A UART (Universal Asynchronous Receiver/Transmitter) is the microchip with programming that controls a computer's interface to its attached serial devices.
Preparation
  • One rock-5c
  • Two female-to-female DuPont cable
Loopback test
Enable Overlay
Please refer to Device Tree Configuration to enable UART Related Overlay, eg: "Enable UART4-M2".
Connection
As shown in the figure, short the Radxa ROCK 5C UART4-M2's PIN_7 and PIN_29
uart connection
Test
  • Open a terminal and enter the following command in the terminal to set the serial port parameters
  radxa@rock-5c:~$ sudo stty -F /dev/ttyS4 speed 115200 cs8 -parenb -cstopb  -echo
  • In the terminal, enter the following command to send data cyclically
  radxa@rock-5c:~$ while true ;do echo "sss" > /dev/ttyS4; sleep 1; done;
  • Create a new terminal and enter the following command to receive data
  radxa@rock-5c:~$ sudo cat  /dev/ttyS4
Transceiver test
Enable Overlay
Please refer to Device Tree Configuration to enable UART Related Overlay, eg: "Enable UART4-M2 and UART6-M1".
Connection
Connect UART4-M2 and UART6-M1 as follows
UART4-M2<-->UART6-M1
PIN_7<-->PIN_21
PIN_29<-->PIN_19
As shown:
uart connection
Test
  radxa@rock-5c:~$ sudo stty -F /dev/ttyS6 speed 115200 cs8 -parenb -cstopb  -echo
UART4-M2 i.e ttyS4 as the sender
UART6-M1 i.e ttyS6 as the receiver
  radxa@rock-5c:~$ sudo cat  /dev/ttyS6
  • validate
The test is successful if the sender successfully sends and the receiver successfully receives the character "ssss".
  • Swap sender and receiver for cross validation
