Deploy YOLOv5 Object Detection on the Board
This document demonstrates how to perform on-device inference for YOLOv5 object detection models on Rockchip RK3588/3566 series chips. For environment setup, refer to RKNN Installation.
This example uses a pre-trained ONNX model from the rknn_model_zoo as a case study, showcasing the complete workflow from model conversion to on-device inference.
Deploying YOLOv5 with RKNN involves two steps:
- Use
rknn-toolkit2
on a PC to convert models from various frameworks to RKNN format. - Use the Python API of
rknn-toolkit2-lite
on the device for model inference.
Model Conversion on PC
Radxa provides a pre-converted yolov5s_rk35XX.rknn
model. Users can directly skip to On-Device YOLOv5 Inference and skip the PC model conversion section.
Activate the
rknn
Conda environment if you are using Conda:conda activate rknn
Clone the
rknn_model_zoo
repository:git clone -b v2.3.0 https://github.com/airockchip/rknn_model_zoo.git
Download the
yolov5s_relu.onnx
model:cd rknn_model_zoo/examples/yolov5/model
bash download_model.shIf network issues occur, download the model from this page and place it in the appropriate directory.
Convert the model to RKNN format using
rknn-toolkit2
:cd rknn_model_zoo/examples/yolov5/python
# Example:
python3 convert.py ../model/yolov5s_relu.onnx rk3588 i8 ../model/yolov5s_relu_rk3588.rknnParameter explanation:
<onnx_model>
: Path to the ONNX model.<TARGET_PLATFORM>
: Target NPU platform. Options includerk3562, rk3566, rk3568, rk3576, rk3588, rk1808, rv1109, rv1126
.<dtype>
: Choosei8
for int8 quantization orfp
for fp16 quantization. Default isi8
.<output_rknn_path>
: Path to save the RKNN model. Defaults to the same directory as the ONNX model.
Transfer the RKNN model to the target device.
For users of RK356X products, you need to enable the NPU in the terminal using rsetup before using the NPU: sudo rsetup -> Overlays -> Manage overlays -> Enable NPU
, then restart the system.
If there is no Enable NPU
option in the overlays options, please update the system via: sudo rsetup -> system -> System Update
, restart, and execute the above steps to enable the NPU.
(Optional) Download pre-converted YOLOv5s RKNN models provided by Radxa:
Platform Download Link rk3566 yolov5s_rk3566.rknn rk3568 yolov5s_rk3568.rknn rk3588 yolov5s_rk3588.rknn -
Modify
rknn_model_zoo/py_utils/rknn_executor.py
(backup the original code):from rknnlite.api import RKNNLite as RKNN
class RKNN_model_container():
rknn = RKNN()
rknn.load_rknn(model_path)
ret = rknn.init_runtime()
self.rknn = rknn
def run(self, inputs):
if not self.rknn:
print("ERROR: RKNN has been released")
return []
inputs = [inputs] if not isinstance(inputs, (list, tuple)) else inputs
return result
def release(self):
self.rknn.release()
self.rknn = None -
Update line 262 in
rknn_model_zoo/examples/yolov5/python/yolov5.py
(backup the original code):262 outputs = model.run([np.expand_dims(input_data, 0)])
Enter the virtual environment:
Refer to Python Virtual Environment Usage.
Install therknn_toolkit-lite2
Python API as described in Install rknn_toolkit-lite2 Python API in a virtual environment on the board. -
Install dependencies:
Run the YOLOv5 example:
python3 yolov5.py --model_path <your model path> --img_saveIf using a custom-converted model, copy it from the PC to the device and specify the path with
--model_path
.(.venv) rock@rock-5b-plus:~/rknn_model_zoo/examples/yolov5/python$ python3 yolov5.py --model_path ./yolov5s_relu_rk3588.rknn --img_save
use anchors from '../model/anchors_yolov5.txt', which is [[[10.0, 13.0], [16.0, 30.0], [33.0, 23.0]], [[30.0, 61.0], [62.0, 45.0], [59.0, 119.0]], [[116.0, 90.0], [156.0, 198.0], [373.0, 326.0]]]
W rknn-toolkit-lite2 version: 2.3.0
I RKNN: [07:00:34.201] RKNN Runtime Information, librknnrt version: 2.3.0 (c949ad889d@2024-11-07T11:35:33)
I RKNN: [07:00:34.201] RKNN Driver Information, version: 0.9.6
I RKNN: [07:00:34.202] RKNN Model Information, version: 6, toolkit version: 2.3.0(compiler version: 2.3.0 (c949ad889d@2024-11-07T11:39:30)), target: RKNPU v2, target platform: rk3588, framework name: ONNX, framework layout: NCHW, model inference type: static_shape
W RKNN: [07:00:34.225] query RKNN_QUERY_INPUT_DYNAMIC_RANGE error, rknn model is static shape type, please export rknn with dynamic_shapes
Model-./yolov5s_relu_rk3588.rknn is rknn model, starting val
infer 1/1
IMG: bus.jpg
person @ (209 243 286 510) 0.880
person @ (479 238 560 526) 0.871
person @ (109 238 231 534) 0.840
person @ (79 353 121 517) 0.301
bus @ (91 129 555 464) 0.692
Detection result save to ./result/bus.jpg ```
Example Output:
```plaintext
Detection result saved to ./result/bus.jpgParameter explanation:
--model_path
: Path to the RKNN model.--img_folder
: Folder of images for inference. Default:../model
.--img_save
: Save inference results to./result
. Default:False
All inference results are saved in
./result
