Radxa Penta SATA HAT
Radxa ROCK Penta SATA HAT is an addon HAT designed for ROCK Series. It utilizes the high speed PCIe buses on ROCK Series and provides a complete NAS solution based on ROCK Series.
Currently supported Radxa ROCK Series products:
- ROCK 3A
- ROCK 3C
- ROCK 4A / 4B
- ROCK 4A+ / 4B+
- ROCK 4SE
- ROCK 5A
Featureβ
- Up to 5x HDD/SSD, support 2.5inch or 3.5inch SSD, up to 100T Storage
- 4x SATA + 1x eSATA with power
- Utilize PCIe buses on ROCK Series
- External standard ATX power supply support for HDD and ROCK Series
- 12V DC power input for 2.5/3.5 HDD power and ROCK Series
- Support HDD suspend mode
- Support software RAID 0/1/5
- Optional PWM control fan for HDD heat dispatching
- Optional OLED display for IP/Storage info
If you use large capacity 3.5-inch mechanical hard drives on the Penta SATA HAT, you need to check the hard drive specification to determine the peak current of the hard drive. We recommend using a hard drive with a peak current less than 1.7A.
Package Listβ
Copper Pillar for fixing
Adapter Board
IPEX Cable
Penta SATA HAT Kit with ROCK 5A support
Penta SATA HAT with ROCK 3A / 4A / 4B / 4A+ / 4B+ / 4SE support
Penta SATA HAT with ROCK 3C support
