Raspberry Pi 5 Use Penta HAT
The Raspberry Pi 5 has a PCIe port that works well with the Radxa Penta SATA HAT.
Power supply selection
Penta SATA HAT is equipped with a DC interface (socket specification is outer diameter 5.5mm, inner diameter 2.5mm, center is positive) and a D-shaped 4PIN interface. When used with Raspberry Pi 5, it supports three power supply modes to adapt to different usage scenarios:
  • Use a Type-C adapter to power the Raspberry Pi 5
  • Use a DC 12V adapter to power the Penta SATA HAT
  • Use a D-shaped 4PIN from an ATX or SFX power supply to power the Penta SATA HAT
The choice of which power supply method to use depends on the number of hard drives we install and other external devices we need to use, such as U disks and fans. The Raspberry Pi 5 has a power consumption of about 8 watts under high load. Typical hard disk power consumption is as follows:
Hard disk typePower consumption
2.5-inch SSDLess than 3W
2.5-inch HDD3-5W
3.5-inch HDD5-10W
We can choose the appropriate power supply method according to the type and number of hard disks installed. Here are two examples:
  • If we install 2 2.5-inch solid-state drives and there are no other external devices on the Raspberry Pi 5, we can use a Type-C adapter for power, such as the Raspberry Pi official 27W PD adapter, which should meet the power supply requirements.
  • If we install 4 3.5-inch mechanical hard drives, considering the power consumption of the Raspberry Pi 5 itself, the total power consumption of the entire kit may exceed 50W. At this time, we can use a DC 12V adapter for power, such as a 12V/5A adapter. Or use a D-shaped 4PIN from an ATX/SFX power supply, D-shaped 4PIN interface generally can provide a larger power.
info
  1. Please do not use two or more power supply methods at the same time.
  2. If you need to use the eSATA interface, you need to use a DC 12V adapter or ATX/SFX power supply.
Assemble
Please assemble in the order shown in the picture below.
  1. Installing column step1 step2
  2. Installing an FPC step3 Please note that the black side of the FPC is facing us. step4
  3. Put together step5
  4. Installing disks step6 step7 step8
Install the system
Please go to https://www.raspberrypi.com/software/ to download Raspberry Pi Imager and install. Insert the microSD card into the USB port on your computer.
  1. Open Raspberry Pi Imager step1
  2. Select the device, and select Raspberry Pi5 step2
  3. Select a system, Raspberry Pi OS (64-bit) is recommended step3
  4. Select the microSD card device you want to insert step4
  5. Edit Settings step5
  6. Add user step6
  7. Enable SSH step7
  8. Start write step8
  9. Complete installation step9
Start Use
Insert the installed system microSD card into the Raspberry Pi and use 12V/5A power supply from the Radxa Penta SATA HAT DC seat. Let's ssh into Raspberry Pi.
ssh pi@raspberrypi.local
Enable PCIe
Edit /boot/firmware/config.txt and add dtparam=pciex1 to the end of the file, save and reboot.
step1
Check disk
Use the lsblk command to view disk devices.
lsblk
step2
Speed test
Here is a simple speed test, which is relatively low due to the use of a mechanical hard disk.
sudo dd if=/dev/zero of=/dev/sda bs=32M status=progress count=100 oflag=direct
step3
Forcing Gen 3
Adding dtparam=pciex1_gen=3 to /boot/firmware/config.txt will force the Raspberry Pi 5 to use PCIe Gen 3.
step4
After adding and rebooting, you can use the following command to check the link status of the Radxa Penta HAT.
sudo lspci
sudo lspci -vvv -s 0000:01:00.1 | grep LnkSta
step5
After seeing the Gen 3 in use, we can measure the write speed again.
step6
3D print case
We have not yet produced the corresponding case for sale. But we and the community users have provided some very nice 3D printed cases, you can try to print these cases:
Case namePreviewDownload linkAuthorNote
Radxa Penta NAScase-1GrabCADRadxa ComputerSupports installation of Top board
Issue discussion: Raspberry Pi 3D print penta hat case quirks
Pi 5 Four Bay NAScase-2MakerWorldMichael KlementsVideo: I Built A 4-Bay NAS Using A Raspberry Pi 5
Pi 5 NAS TOWERcase-3Cults 3DCeIIyNoctua 8CM fan, excellent heat dissipation
Pi 5 NAS BOXcase-4MakerWorldWikiZellHard disk is easy to plug and play
Radxa Penta Casecase-5PrintablesPatrick Friedel8CM fan, excellent heat
