Create RAID Arrays with mdadm
mdadm is a Linux software RAID tool that can be used to create, manage, and monitor software RAID arrays. In this guide, we will show you how to create RAID 0, RAID 1, RAID 5 and RAID 10 arrays using mdadm.
Install mdadm
Before getting started, make sure that mdadm is installed. If it is not installed, you can install it using the following commands:
sudo apt install mdadm
Create a RAID 0 Array
RAID 0 is a striped array that divides data into blocks and distributes it across multiple disks. RAID 0 provides faster read and write speeds but does not provide redundancy. To create a RAID 0 array, you will need at least 2 disks. Follow these steps:
Use the
lsblk
command to view the available disks:lsblk
Use the
mdadm
command to create a RAID 0 array:sudo mdadm --create --verbose /dev/md0 --level=0 --raid-devices=2 /dev/sda /dev/sdb
Replace
/dev/sda
and/dev/sdb
with your disk names. -
Format the RAID 0 array:
sudo mkfs.ext4 /dev/md0
Mount the RAID 0 array:
sudo mkdir /mnt/raid0
sudo mount /dev/md0 /mnt/raid0
While RAID 0 can provide more space and better performance, the entire system is very unreliable. If a failure occurs, there is no way to recover the data. Therefore, RAID 0 is generally only used in situations where data security is not a high priority.
Create a RAID 1 Array
RAID 1 is a mirrored array that copies data to multiple disks. RAID 1 provides redundancy but slower read and write speeds. To create a RAID 1 array, you will need at least 2 disks. Follow these steps:
Use the
lsblk
Use the
mdadm
command to create a RAID 1 array:sudo mdadm --create --verbose /dev/md0 --level=1 --raid-devices=2 /dev/sda /dev/sdb
Replace
/dev/sda
and/dev/sdb
Format the RAID 1 array:
Mount the RAID 1 array:
sudo mkdir /mnt/raid1
sudo mount /dev/md0 /mnt/raid1
Create a RAID 5 Array
RAID 5 is a striped array that divides data into blocks and distributes it across multiple disks, but it adds parity operations. To create a RAID 5 array, you will need at least 3 disks. Follow these steps:
Use the
lsblk
Use the
mdadm
command to create a RAID 5 array:sudo mdadm --create --verbose /dev/md0 --level=5 --raid-devices=3 /dev/sda /dev/sdb /dev/sdc
Replace
/dev/sda
,/dev/sdb
, and/dev/sdc
Format the RAID 5 array:
Mount the RAID 5 array:
sudo mkdir /mnt/raid5
sudo mount /dev/md0 /mnt/raid5
RAID 5 provides better performance and redundancy, but there is some performance loss when writing data. If a disk fails, the RAID 5 array can continue to work, but when replacing the failed disk, the entire array needs to be rebuilt, which may take some time and is also easy to damage other disks.
Create a RAID 10 Array
RAID 10, also known as RAID 1+0, first mirrors (RAID 1) and then stripes (RAID 0). To create a RAID 10 array, you will need at least 4 disks. Follow these steps:
Use the
lsblk
Use the
mdadm
command to create a RAID 10 array:sudo mdadm --create --verbose /dev/md0 --level=10 --raid-devices=4 /dev/sda /dev/sdb /dev/sdc /dev/sdd
Replace
/dev/sda
,/dev/sdb
,/dev/sdc
, and/dev/sdd
Format the RAID 10 array:
Mount the RAID 10 array:
sudo mkdir /mnt/raid10
sudo mount /dev/md0 /mnt/raid10
RAID 10 provides better performance and redundancy, but requires more disks. If a disk fails, the RAID 10 array can continue to work, and the rebuild speed is faster than the RAID 5 array.
